help!!! just got my swap and the car keeps bogging down
Old Jul 13, 2005 | 06:33 PM
hitman619's Avatar
hitman619
SDSU Basketball
Default help!!! just got my swap and the car keeps bogging down
just had a 95 gsr put in to my 93 civic keeps bogging down in 1st 2nd and thrid hell even fourth change fuel pump dist fuel pressure reg checked the ecu no codes no check engine light nothing plz help i just paid 3500 for this swap im already madd as help cause the guy said he could retain the ac and then said i don't know how to do it and he owns a honda junk yard could it be my mods plz help fellow honda acura owners
Old Jul 14, 2005 | 01:25 AM
AcsRcool's Avatar
AcsRcool
Faster than your Geo
Dood, start with some punctuation so we know what the hell you are saying.
Coherent sentences = good
Old Jul 14, 2005 | 04:26 AM
mberndt's Avatar
mberndt
Yes yes, please use some punctuation...
First off, I think I had the same prob you have...
I have a B16A swap, GSR head, full mods, etc., It's been through hell and back, but my first swap was a 1st gen B16A into 93 civic d, and this is how that engine blew up...
Check your ignition timing, and make sure the belt hasn't skipped a tooth, cause mine would drive ok if u gave it gas from a start, but if u let off for just a second, it would bog down and go NOWHERE, then would only rev up again if u put in clutch and gave it some gas with no load.
I revved mine up to like 8200 when i was ripping on it cause it was reallyb slow for it having a swap, and it blew up!! in the number one cylinder, one of the intake valve retainers broke, letting the valve fall into the chamber!!
After it stopped running and would'nt crank over, i had the head pulled after we found out the timing belt didn't break, that's whne we found the incredible damage... the piston had a 2in dia hole mashed/melted through and u could see the crank, whole motor was totalled, cause little tiny metal shvings were in EVERY cylinder...Don't drive it like that it could be permanently damaged...Take it back to the guy who did the swap...
So, check your timing that's what makes it bog down, maybe fuel prob but unlikely...
hope this helps,
Later,
Mike
Old Jul 14, 2005 | 01:46 PM
hitman619's Avatar
hitman619
SDSU Basketball
sorry bout that guys. but hey!!!!that was it my aem gears were loose. hence the belt was loose. going back to the junk yard today to pick up. hey sorry bout your engine!!! i hope to
help people in the future. ive own accords all my life,so that's all i know!!!! this car screams down the road. with just bolt on parts thanks again!!!!!
Old Jul 29, 2005 | 09:07 PM
brettybaby's Avatar
brettybaby
i have the same problem i threw in some bosh 4 head spark plugs today and it seems a little better but its kinda bogging! is it the timing. i change my f22a1 motor for another f22a1 because my last one had a hole in it
its running kinda sluggish with brand new bosh 4 head plugs the platinum 3 plugs
