B20 swap
Old Jul 12, 2005 | 04:27 PM
Negrodamus's Avatar
Negrodamus
Default B20 swap
Has anyone in Cali been successful in doing a legal b20 swap? Im curious to know.
Tommy K
Old Jul 12, 2005 | 07:27 PM
VTEC-Power's Avatar
VTEC-Power
I know people who have done it, legal I don't know
Old Sep 1, 2005 | 11:13 PM
Techme06's Avatar
Techme06
Eg b20b turbo
i have that set up . nope no legal . it's a Light truch engine in a compact car . not legal, only for off road uses. but what they don't knoe wouldn't hurt them . it'll pass smog if they don't knoe what they are looking at.
Old Sep 2, 2005 | 04:39 AM
teggyls's Avatar
teggyls
J-villan
theres no way a non-honda-engine-knowing-person can tell the difference by looking at it. its identical to the b1, except for the b20 stamp on the block.
i have one in mine, but theres no emissions in fl, so i dont know or even care if its legal.
Old Sep 2, 2005 | 06:22 AM
Brar's Avatar
Brar
wtf truch? wasnt it in the preludes? lol
Old Sep 2, 2005 | 06:28 AM
teggyls's Avatar
teggyls
J-villan
your thinking of the b20a which was in the 88-91 ludes. the crv's came with the b20b
also the b21 was in the 90-91 prelude si's
Old Sep 2, 2005 | 08:44 AM
Brar's Avatar
Brar
so wtf is a truch? also cant u just bar then engine to pass smog? thats wat people do with b16s...
Old Sep 2, 2005 | 09:11 AM
teggyls's Avatar
teggyls
J-villan
i think he meant truck, the H is only 2 spaces away from the K, lol.
Old Sep 2, 2005 | 01:27 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Umm, wait a second...:thinking:
The EPA classification is a little murky. I've never heard getting busted for that aspect of a swap.. but according to the latest EPA report... you're right, the CR-V is listed under "Special purpose vehicle 4WD".
http://www.epa.gov/otaq/cert/mpg/readme.txt
On a general note:
In California, you can swap any motor into any chassis as long as you play by the rules..
From: http://www.arb.ca.gov/msprog/aftermkt/replace.htm
To wit:
Replacement Engines
Entire engines can be replacement parts. As with any other replacement part, the engine must be identical to the original.
If the replacement block or engine is obtained without emissions equipment, all the equipment from the original engine must be installed on the replacement block.
If the engine is not identical to the original then it is not a replacement part, instead it is considered an engine change.
Engine changes are a modification that must meet certain requirements to be legal (please see "Engine Changes").
Japanese Replacement Engines
Used engines imported from Japan can be used as replacement engines as long as the engine being used has been identified as functionally identical to the original engine. Please refer to the engine importers catalogue to determine if a replacement engine is legal for installation in your vehicle.
Engine Changes
Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle:
* The engine must be the same year or newer than the vehicle.
* The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy-duty truck, etc.) based on gross vehicle weight.
* If the vehicle is a California certified vehicle then the engine must also be a California certified engine.
* All emissions control equipment must remain on the installed engine.
After an engine change, vehicles must first be inspected by a state referee station. The vehicle will be inspected to ensure that all the equipment required is in place, and vehicle will be emissions tested subject to the specifications of the installed engine.
Moved to Hybrid forum.
Old Sep 2, 2005 | 01:28 PM
TheOtherDave™
Apathy Kills
The old preludes had the B20A.
The H-series Preludes are in the same class as the Integra.
Check out the EPA file I linked.
