just a couple of tips...
Old Jun 21, 2005 | 02:56 PM
Nconstruction's Avatar
Nconstruction
Default just a couple of tips...
These are a couple of tips my teacher from school enlightened me on. I go to UTI an automotive trade school, and believe me, these teachers know their spit. If you want to increase your gas mileage, (this sounds crazy, but i believe him) get a spray bottle filled with water and take of your intake tube. Then while the engine is running, spray water into your throttle body SLOWLY about three or four times. Have someone inside the car while you are doing this, cause they are going to have to give it gas a couple of times to keep the engine running. What this does, is it helps to get the carbon build up off the top of the pistons. The carbon build up on the pistons is what can cause detonation. Keeping your pistons clean will help to get a better combustion in turn meaning better gas mileage.
Theres also another tip that my teacher told me. When you do an oil change, add a quart of ATF fluid to your car, the ATF has a LOT of conditioners that will help to keep your seals looking new. Just Make sure that if you do this, that you change your oil EVERY 3,000 miles. If you keep the ATF in for too long it will fuck up your bearings. So if your going to do it, do it right.
My last tip is a simple one that many people seem to overlook. How often do you change your oil? I'd recommend you do it every 3000 miles. Why, because I said no. hahaha, j/k The reason why that is soooo important isn't because it's just good for your car, but because the oil filters are only made to go 3000 miles. They make synthetic oils and what not, but do they make synthetic filters? I've never seen one that specifically said, "MADE TO LAST 7000 MILES" So even though you use synthetic, i'd still change it every 3000, it'll help your engine last longer and depending on what type of oil u use, it'll make your car run that much better. Take an old bolt and rub it on your driveway as fast as you can, thats what happens when you run your car with bad oil. Oil breaks down and thats when trouble occurs
Old Jun 22, 2005 | 12:34 AM
dustimus's Avatar
dustimus
Better golfer than you
lol.... spray water in my engine while it's running. YAAAAAAAAAAAA RIGHTTTTTTT
Old Jun 22, 2005 | 12:50 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
The water trick has been a long known trick in the rotary world, but seeing as how piston motors like to hydrolock alot easier then rotaries, no way would I try that on a piston motor.
Old Jun 22, 2005 | 05:12 AM
shivers's Avatar
shivers
Moderator Alumni
He's talking about spraying in a fine mist that will not hydrolock the engine. There are plenty of kits available that do this for you (AquaMist, etc.). The fine mist of water cools the charge and helps prevent detonation. As a side benefit, the mist helps to keep the combustion chambers clean. This is more beneficial to boosted applications, but can be of benefit to n/a applications as well.
2005 s2000
Old Jun 22, 2005 | 06:00 AM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Any car/engine that is driven in the heavy rain is going to get a little bit of water in it. It's a safe bet that during extreme rainy conditions when you can barely see and you're almost hydroplaning and there's just water every-frikin-where that your engine is pulling in some pretty wet air because while it's raining like that the humidity is usually at around 100% and all that splashing is bound to get a little spray up near the intake.
I think the fine mist metioned above is actually a naturally occoring event. Hydrolock on the other hand is where the intake literally becomes a giant straw pulling in water a cup or a pint at a time. It probably takes about that much to hydrolock an engine. Not an eighth of a teaspoon.
I am in no way responsible for engine damage resulting of someone putting water in it.
Old Jun 22, 2005 | 07:50 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
im all set with "misting" water into my throttle body and i change my oil every 2500-3000 miles so i think im all set
Old Jun 23, 2005 | 06:25 AM
b16ahybrid's Avatar
b16ahybrid
He's talking about a spay bottle and misting the water. I've done this for a long time. I usually do this when I change my spark plugs (pretty often) and have never had a problem.It's been done for years, probably as long as cars have been around.
Old Jun 23, 2005 | 07:24 AM
lkailburn's Avatar
lkailburn
college kid
water/alcohol injection is EXTREMELY effective in cooling temps. i didn't know it had cleaning properties aswell. but for my lil daily driver she'll be just fine without it
