Engine Building
Old Jun 16, 2005 | 11:31 AM
1991JDMCRX's Avatar
1991JDMCRX
Default Engine Building
I need to know of places that can build a B18C5 with a 2.2 liter stroker kit. THe engine is N/A and needs to handle up to 600-700HP. Please any info will help.
Old Jun 16, 2005 | 12:47 PM
servion's Avatar
servion
Sorry, you're not going to hit 600whp in a n/a honda, period. I think you should re-adjust your gosal to be a little more reasonable. You can hit 600-700whp with a turbo honda...
Old Jun 16, 2005 | 07:26 PM
Snoopy's Avatar
Snoopy
been there done that
www.importbuilders.com
www.goldeneaglemfg.com
www.erlperformance.com
they can build an engine to whatever you want, can you afford it is the question. dont expect 600-700hp NA from any honda engine.
Old Jun 16, 2005 | 09:14 PM
1991JDMCRX's Avatar
1991JDMCRX
Money is no problem.
Old Jun 16, 2005 | 09:17 PM
1991JDMCRX's Avatar
1991JDMCRX
What is the most HP I can get out of a N/A honda motor?
Old Jun 16, 2005 | 09:30 PM
Illegal B16's Avatar
Illegal B16
New Zealand
300 or so, but good luck. And the money will flow for that. Prob not on pump gass though.
Old Jun 17, 2005 | 04:21 AM
crazy4396063's Avatar
crazy4396063
honda
actually i've read that the b-series was the first 4 cylinder to ever get 100hp per cylinder. However do you realized that the amount of money the honda engineers/drag racing sponsers had to get just before the idea was even put in there head? these guys are the dudes that build the 6 cylinder F1 cars (millions worth of tech. that goes in to that). I hate to kill your idea it would be cool to do ....i have even thought about it myself. if you really want to spend 7-15k on and engine/ not including the tranny or what your going to do with the ecu. then i'll give you the number to my buddy reeves callaway. he used to do euro cars now he does mainly corvette. but he might not even want to waste his time. ether way man. it doesn't look to promising your gonna get past by a 16 year old that did a custom turbo kit for under 2k :bowdown: but if you want to fix your urge build your motor.....simply.......to handle boost. hope this helps give your idea some direction.
Old Jun 17, 2005 | 07:08 AM
Snoopy's Avatar
Snoopy
care to donate some then? h:
there are some guys pushing 300+whp with the k series.
Old Jun 17, 2005 | 07:12 AM
servion's Avatar
servion
You're not going to get that much power out of a 4-cyliner n/a honda, period. You can throw all the money at it you want to, but the pro drag teams are barely making 1/2 that.
For that kind of n/a power, I would suggest building a 8 cylinder musclecar.
If you want to turbocharge it, that's a different story. That can be done fairly easily as long as you have the $$$.
Old Jun 25, 2005 | 08:31 AM
civicandtegra's Avatar
civicandtegra
guys this solution is simple. first get a honda crx, then strip it, make the bay a lil bit bigger and add frame support, than switch to rwd, build some mounts and buy a 305 with a 4sp and build the motor up, drop it in and get a stiff suspension in front so motor doesnt drop the ca rto the ground and boom there u go. real simple huh
the fact of a 4cyl b all motor makin 600-700 would scare the crap out of me, be realistic unless u are the guys at bocies make that project crx
