Apexi vafc2 wiring
Old Apr 26, 2005 | 11:46 PM
tuben's Avatar
tuben
Default Apexi vafc2 wiring
I have a problem with a couple of wires, i am looking were to connect the vtc camsignal, tdc signal, vtm signal.
Pleas help
Old Apr 27, 2005 | 08:12 AM
danteisme's Avatar
danteisme
what car, year, motor, etc...?
edit:
http://www.apexi-usa.com/productdocu...afc_update.pdf
for some cars you dont hook up those wires, for mine (96 gsr) i didnt hook up the vtc wire or tdc signal wire.
Old Apr 27, 2005 | 10:22 AM
tuben's Avatar
tuben
integra type r -98 does it help
Old Apr 27, 2005 | 03:59 PM
danteisme's Avatar
danteisme
ok in that link with the updated wiring diagrams you are goin to use the wires in the diagram wh-2 , so you arent goin to hook up vtc or tdc wire, just tape them off and you can see where the vtm signal wire goes. this help you?
Old Apr 28, 2005 | 03:18 AM
tuben's Avatar
tuben
Thanks i think it will help i´m going to hook it up to night
Old Apr 28, 2005 | 10:31 PM
tuben's Avatar
tuben
I installed the apexi yesterday there was a little problem i didn´t have any wire going in to the vtm signal in the cpu, does the apexi work allright with out it
Old Apr 30, 2005 | 06:28 PM
EGteknikhatch's Avatar
EGteknikhatch
Team Teknik
the reason your having a problem is because vafcs are bad!!!!! bad i tell you!
Old May 2, 2005 | 07:37 AM
tuben's Avatar
tuben
whats good then
Old May 2, 2005 | 08:08 AM
Mario's Avatar
Mario
Hondata would be the ideal choice... the real question is what kind of mods do you have that you think you need to have an AFC for??? Mine is basically a paperweight on my dash... it's a sort of cool device when you first get it.. but then you realize how useless it is.
