Zex questions.
Old Feb 28, 2005 | 11:34 AM
Omniscient's Avatar
Omniscient
warm butter on toast
Default Zex questions.
I was lookin at this realtively cheap ZEX plug and play nos with a smart nmu just for kicks. Then on the site there was this list of warnings. None of them I'm concerned about. But it didn't mention anything if you have a system in the trunk. My question is would the vibration of the system cause the tank to leak or blow? And what if they system shorts or the ground comes loose and causes a spark? Should I worry about that or is it not an issue?
Old Feb 28, 2005 | 08:50 PM
cobbcustomz's Avatar
cobbcustomz
System is not an issue. I had a system directly next to my bottle and it had no negative impact at all.
Old Mar 6, 2005 | 09:27 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
Call ZEX and ask, they have excellent customer service.
Old Mar 11, 2005 | 02:05 PM
olly-civic's Avatar
olly-civic
nitrous oxide isent flamable so sparks wouldnt bother it and youd need some serious system to bother a bottle, bearing in mind you can drop these bottles off buildings and put them on fires..... there built to withstand some sevear conditions,
Old Mar 11, 2005 | 02:21 PM
nex-gensjdmteg's Avatar
nex-gensjdmteg
the only problem that i can see is that you need a bottle heater you keep the gas pressure up
Old Mar 11, 2005 | 02:24 PM
olly-civic's Avatar
olly-civic
nah the heater just maitains a stable bottle pressure, mines always worked fine and have u felt the temparature in the uk!!!!!!!!
Old Mar 17, 2005 | 02:35 PM
civicandtegra's Avatar
civicandtegra
no2 isnt flamable untill it breaks down and freezes the air in the motor, also dont forget no2 is illegal for the street
Old Mar 19, 2005 | 07:01 AM
tonysstudio's Avatar
tonysstudio
i had a dry ZEX kit in my 93 hatch. i also have 2 10's running about 1200 watts. never had an issue. Selling the kit if ya want it.
