smoking-oil in cat?
Old Feb 12, 2005 | 02:32 PM
shawn_crx8891's Avatar
shawn_crx8891
Default smoking-oil in cat?
ok, i have this problem with excessive blue smoke when accelerating. i just replaced the turbo because the old one was leaking oil into the turbine side and there was oil in my exhaust. my question is: could the oil from the old turbo have clogged the catalytic converter so much that it blows heavy smoke when accelerating? i just got it running again today and i let the car idle for a total of probably a half hour and drove around for about 10 minutes, hoping it would burn off and stop, but it didn't. the smoke looks white at idle, and blue when accelerating. any thoughts on this?
Old Feb 12, 2005 | 02:58 PM
b16ahybrid's Avatar
b16ahybrid
This is probably a dumb question but, hows your oil drain line? kinked at all? drains strait down?
Drive it around a bit, you may need to burn off the excessive oil left in your exhaust if the leak was bad enough.
Old Feb 12, 2005 | 03:45 PM
shawn_crx8891
i think the problem with the last turbo was my oil drain line, because it did have a small kink. i made sure to use stainless braided hose this time so there are no kinks. i am really hoping that it just needs to burn off the oil in the exhaust, but it seems like too much smoke to be that. thanks for the suggestion, though.
Old Feb 12, 2005 | 04:14 PM
b16ahybrid's Avatar
b16ahybrid
Is the drain facing strait down or is it angled at all?
Old Feb 12, 2005 | 04:41 PM
shawn_crx8891
i have a 90 degree elbow out of the turbo because my crossmember was in the way and that's the only way i could do it. then there's a gradual curve to the oil pan, but it's all downward. i just went out for another drive and let it get hotter this time and now the smoke smells like burning oil, so i'm guessing it's just the oil leftover in the exhaust...hopefully.
Old Feb 12, 2005 | 04:47 PM
b16ahybrid's Avatar
b16ahybrid
Without actually seeing it, it sounds as though you oil return is backing up...
How large is the return?
Old Feb 12, 2005 | 04:51 PM
shawn_crx8891
not sure exactly, but it's from www.cheapturbolines.com and my last oil line probably had worse flow and i didn't have this problem, not to say you're wrong, though.
Old Feb 13, 2005 | 02:36 PM
shawn_crx8891
problem seems to have cleared up, i drove the car today and didn't notice any smoke other than normal exhaust. thanks for the suggestions.
Old Feb 13, 2005 | 07:30 PM
b16ahybrid's Avatar
b16ahybrid
Glad it wasn't anything big. :thumbup:
