fuel grade?
Old Feb 10, 2005 | 10:33 PM
honda5's Avatar
honda5
Default fuel grade?
I have 95 civic with gsr and wondering what the recomended fuel grade?
thanks!
Old Feb 10, 2005 | 10:38 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Premium Unleaded. 91 octane minimum, 93 is prefferable.
Old Feb 10, 2005 | 10:57 PM
:werd: ^^^ agree with it
Old Feb 13, 2005 | 06:52 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Factory requires Premium. I don't know about anyone else, but I tried to go cheap once and my engine knocked like it wasn't supposed to. Went back to Premium and it went away. Never tried that again.
Old Feb 13, 2005 | 07:07 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
Higher octane fuel isn't a "better" or more powerful blend of gas, but rathrer one that's more resistant to knock, or detonation. If a motor is built for and runs fine on 87, there's not benefit to running anything higher in it. However, if your motor has higher compression, lots of timing or forced induction, the extra knock resistance of higher octane fuels becomes nessicary. All DOHC VTEC engine's require 91 or greater and have a knock sensor that will listen for detonation and pull back the timing to protect the engine but it won't make as much power. Long story short, yes, you need premium fuel.
Old Feb 13, 2005 | 01:25 PM
b16ahybrid's Avatar
b16ahybrid
Agree'd, with that said run 91 octane, no need for anything higher unless your running forced induction or have raised your compression.
You always want to run the lowest octane that you can get away with. Running higher octane will not increase power and may ultimatly effect fuel economy and it will effect your wallet in a negative way.
