Moisture in Exhaust??
Old Feb 10, 2005 | 04:35 PM
doublebullz's Avatar
doublebullz
Default Moisture in Exhaust??
After my 94 integra RS runs a while there seems to be alot of moisture buid up in the exhaust.If I am on an inclione you can see it run out.I am not losing any coolant though soooooooooo where could this be coming from??
Old Feb 10, 2005 | 06:25 PM
ED9man's Avatar
ED9man
driver
It's called a combustion reaction, this goes on quite a bit in your internal combustion engine. It goes like this (ideally): oxygen and a hydrocarbon (gasoline) react to produce carbon dixoide and water. It's just condensation in your muffler, nothing to worry about.
Old Feb 10, 2005 | 07:54 PM
doublebullz
I can see a little moisture but this seems to pour out
Old Feb 10, 2005 | 09:11 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The water vapor from the reaction condenses with the cold air outside to create water in liquid form. Totally normal. You should only be experiencing this during warmup.
Old Feb 10, 2005 | 11:24 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
ditto
Old Feb 18, 2005 | 06:22 AM
lkailburn's Avatar
lkailburn
college kid
hahahahah coolant out your exhaust now THAT would be bad
but ya as stated the moisture is normal during warmups. should go away after that
