97 civic ex motor knock
Old Jan 31, 2005 | 04:50 PM
mullens97ex's Avatar
mullens97ex
Default 97 civic ex motor knock
My motor will knock at all RPMs and gets louder as I rev higher. Are the valves out of adjustment and tapping the pistons ? Or could it be something less serious?
Old Jan 31, 2005 | 04:59 PM
mullens97ex
My motor will knock at all RPMs and get louder as engine speed increases. Not sure if valves are out of adjustment or what. Could it be somthing more serious or just valve tap, this problem has been going on for 4 mos. and has not gotten any worse over that time. any info would help @ this point.
Old Jan 31, 2005 | 05:01 PM
mullens97ex
get a b18
Old Jan 31, 2005 | 05:04 PM
olly-civic's Avatar
olly-civic
if the valves are touching the pistons is fooked if the big ends are knocking its fooked
like mullens said .............b18
Old Jan 31, 2005 | 05:11 PM
hondaman1320's Avatar
hondaman1320
yeh, get a B18B1 and a drag turbo man
Old Jan 31, 2005 | 10:34 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by mullens97ex
get a b18
Real constructive.
Get a valve adjustment firstly. They are easy enough to do yourself. Then if that doesn't fix it, it may be an issue with detonation. Retard the ignition timing a bit and see if that helps.
Old Jan 31, 2005 | 10:44 PM
Provocateur
On permanent hiatus
Get the valves adjusted. It is simple enough to do yourself. It couldn't hurt to be certain that your valve lash is within spec.
