Crank pulley
Picked up a new crank pulley for my b18c1. Only runs 1 belt, which is great, considering I no longer have AC or PS.
Changed my timing belt and water pump. Discovered that the belt still has its little hash marks on it and the pump is in pristine condition. Apparently it was changed.
But anyway, I've broken two belts trying to hold the crank pulley steady while torquing down the crank bolt. My compressor doesn't quite lend my impact enough power to get it on properly.
Is there a trick to this? I've checked everywhere looking for the crank pulley tool, and the closest availabilty is 4 weeks. Should I just plop this beast into 5th and wrench on it?
Yup just put it into 5th and do what you can. Having a small compressor blows!
I had to jam a moster screw driver into the flywheel to tighten my new pulley. Call it what you will i felt a difference after i changed the crank pulley?? BTW how do you like the new pulley, any difference?:thumbup:
Originally posted by qtiger
There's a difference all right. 4 pounds!
or maybe my driving got better...
gaydm.accord
Sep 1, 2005 10:27 AM
Tr0LL
Engine Swaps, Tech & Tuning
5
Mar 24, 2003 05:26 PM
Tr0LL
4
Mar 24, 2003 05:24 PM
jdmcrx22
Jan 15, 2003 06:38 AM
DoodooMonster
Aug 18, 2002 02:46 PM
