question about valve maintenance
Old Jan 20, 2005 | 02:38 PM
THC's Avatar
THC
Default question about valve maintenance
hey i'm adjusting the valves on a f22b1... i start off by rotating the camshaft pulley until it says 'UP" at the very top.
i adjusted first the exhaust valves and then the intake valves according to spec.
then according to instructions i rotate the camshaft pulley 90 degrees counter-clockwise until the UP mark is on the left side, pointing towards the car's windshield...
according to instructions here i'm supposed to proceed adjusting the 3rd piston's valves... but (unlike the first piston's valves) i checked the valve clearances FIRST before adjusting them, and i can barely even fit a .003 feeler in there...
if the valves are that far off spec, wouldnt they have burnt up or something by now? or am i just doing something wrong? or am i totally right and need to go ahead and adjust them back to spec?
thanks guys.
Old Jan 20, 2005 | 05:20 PM
dustimus's Avatar
dustimus
Better golfer than you
Adjust them to spec.
Old Jan 20, 2005 | 10:40 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
They won't burn up but they will create some unnecessary friction if they are too tight. That is usually the noise you hear when you are in need of a valve lash adjustment. If they are too loose, the valves aren't opening far enough, so power losses are noted. The procedure you describe is right. To make sure, the cam lobe should not even come close to the rocker arm pads when you are adjusting. Sounds like everything you are doing is right, so at this point, adjust to spec and see if there is a notable difference in sound/power.
