Sqeaky Clutch?
Old Aug 20, 2002 | 05:54 AM
TwilightX's Avatar
TwilightX
Default Sqeaky Clutch?
I've got this problem with my clutch that just surfaced a couple days ago...it seems every time I depress the clutch or let off on it, it sqeaks, and it sounds like it's coming from outside the engine compartment...is it just something that needs to be oiled? Prior to that, the clutch would make a clicking noise when I pushed it in all the way...but it would go away if I pumped the clutch for a couple times.
Any ideas what this could be or what I need to do? It's on a 97 Civic DX...thanks for any help guys!
T-X
Old Aug 20, 2002 | 07:46 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Common consensus on previous threads like this say it's the throwout bearing pivot pin in the bearing fork that needs taken out and re-greased.
-Harry
AIM: NDcissive
Old Aug 20, 2002 | 08:54 AM
TwilightX's Avatar
TwilightX
So it's not an issue with the tranny or clutch needing to be replaced? I tried doing a couple searches and came up with nada except some GSR's having different problems...
Old Aug 20, 2002 | 08:57 AM
1stGenCRXer
You might also try checking/bleeding the clutch system fluid. A squeak would be metal on metal rubbing, but a more serious clutch problem would normally surface under accleration conditions.
Old Aug 22, 2002 | 12:10 PM
TwilightX's Avatar
TwilightX
Well, I checked with a friend who works on engines and he says that it's either the springs or the cable itself...he noticed it went away past the engagement point, so I can either live with it or have it serviced, which means taking out the tranny from the body. So I think for the time being, I'll live with it since it's not a serious thing. Thanks for the help!
T-X
stackbundles
92+ Civic/EL & Del Sol
2
Oct 25, 2006 05:45 AM
ugosplat
7
Jun 23, 2005 03:33 PM
DMA94ls
3
Jul 19, 2003 05:36 PM
midwestgsr
Engine Swaps, Tech & Tuning
2
Apr 29, 2003 09:04 PM
delsolLs
Nov 11, 2002 08:49 AM
