cooling problems in ohio
Old Dec 2, 2004 | 10:06 AM
sonicivic's Avatar
sonicivic
Default cooling problems in ohio
have a 92 hatch d16z6 with greddy turbo kit and intercooler. it seems to be pushing the coolant out of the radiator into the overflow tank, this happened after I boostedit to 7psi can any one help me?
Old Dec 2, 2004 | 10:34 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
There is no reason why the boost should be even touching the coolant. Is it overheating the car? It is normal for coolant to go into the tank as it expands due to heat.
Old Dec 2, 2004 | 12:50 PM
BoostedITR41's Avatar
BoostedITR41
unless a sleeve is cracked and pushing coolant with presure or a blown head gasket can do that too
Old Dec 2, 2004 | 06:02 PM
Provocateur
On permanent hiatus
True but I am sure it would be a little more of a problem than just filling the reserve tank.
Old Dec 2, 2004 | 08:29 PM
BoostedITR41
not always sometimes HG shows no signs of being bad on the outside it is just little stuff
