Which Walbro should I get?
Old Nov 28, 2004 | 02:21 AM
CRAZYEG9's Avatar
CRAZYEG9
THE TRUE O.G.
Default Which Walbro should I get?
I have a 92 Civic, and there is an 85% chance my fuel pump is bad because when I drive, power cuts of for about 3 seconds every 20 seconds,(feels like I let off the gas for 3 seconds when I didn't) and I already changed fuel filter, plugs, wires, cap, and rotor. What I'm going to do is get a Walbro after I do my B20 swap. The question is which one should I get the Walbro 190lph Fuel Pump, or the Walbro 255lph Fuel Pump. I will be going NA all the way with moderate mods. Also will these pumps make me burn more gas.
Old Nov 28, 2004 | 06:42 AM
SRT_Andy's Avatar
SRT_Andy
190LHP - the 255 will be overkill. The small one will support 300hp.
Old Dec 1, 2004 | 04:13 PM
1jz gte_ jza70's Avatar
1jz gte_ jza70
rhd the only way to be!!!
im sure you could still have the option of the 255 but youll need a fuel pressure regulator but i would only get the 255 if your looking at higher horse power numbers then 300
Old Dec 3, 2004 | 01:23 AM
Eddiebx's Avatar
Eddiebx
yah 190lph is more than ehough
Old Dec 3, 2004 | 06:28 AM
xenocron's Avatar
xenocron
agreed...make sure you dont get the HP (high pressure) version of either of those pumps
