What is a Long Block?
Old Nov 22, 2004 | 08:06 AM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
Default What is a Long Block?
What is a long block and why is it so much cheaper?
What would I need to do to make it run?
Old Nov 22, 2004 | 08:17 AM
Long blocks far aw i know are just the engines itself. Not the complete swap. Thats just my guess from being on Hmotorsonline.com all the time
Old Nov 22, 2004 | 11:14 AM
Kai's Avatar
Kai
Rotorphile.
Piston engines:
"Short" block: the lower half of the engine, from the headgasket down (no head or heads, depending on engine.)
"Long" block: the entire engine, sometimes with manifolds.
Rotary engines:
"Short" block: just the assembled engine.
"Long" block: assembled engine with manifolds.
Long blocks are cheaper because it's just the engine. What one needs to "work" depends on the engine and intended body.
Old Nov 22, 2004 | 11:26 PM
dubcac's Avatar
dubcac
I
Longblock is a complete engine from oil pan to valve cover, without transmission.
Old Nov 23, 2004 | 12:02 AM
augy's Avatar
augy
Originally Posted by Kai
Piston engines:
Rotary engines:
The long block is the engine, the short block is the bottom half of the engine, yet the short block costs more?
Old Nov 23, 2004 | 07:52 AM
Kai's Avatar
Kai
Rotorphile.
Not sure where you are shopping, but a shortblock should never be more expensive then the a similar model longblock.
Old Nov 27, 2004 | 09:14 PM
augy's Avatar
augy
Well, you said "longblocks are cheaper because..." and I figured you meant cheaper than a shortblock.
Old Nov 27, 2004 | 09:30 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
No, cheaper than a whole swap.
-Harry
AIM: NDcissive
Old Nov 28, 2004 | 10:56 AM
Kai's Avatar
Kai
Rotorphile.
Bingo. It was in reference to the original question "Why is a longblock cheaper (then a complete swap)"
