Will A B18B1 Engine Fit in a 94 civic?
Old Nov 11, 2004 | 02:22 PM
SlowRider's Avatar
SlowRider
Default What ecu.
Wich ecu and axles will I need to put a b18b1 in my 94 civic?
Old Nov 12, 2004 | 05:45 PM
Kai's Avatar
Kai
Rotorphile.
92-93 PR4 or 94-95 P74/5, for manual transaxle.
94-01 Integra intermediate shaft and axles.
Old Nov 13, 2004 | 03:53 AM
SlowRider's Avatar
SlowRider
Can I use the tranny from a B18A1 92 Integra on my B18B1 97 Integra ib my 94 Civic? With the axles to?
Old Nov 13, 2004 | 02:44 PM
Running925's Avatar
Running925
Your Powder Coater
Kai..i believe the PR4 is the 90-91 (obd0) ECU.. which has a different plug than the 94 Civic Does.
SlowRider you are going to need the ECU from the 92-93 Integra (obd1).
Also, the tranny that you are asking about.. B18A1.. is a cable tranny & the 94 civics are setup for hydrolic transmission. You can make it work if you would like to. In order to do so i would suggest the Hydro to Cable conversion from HASport. & use the Axles that goe with the tranny that u plan to install.
Rule of Thumb. All B series trannys will work with all B series motors.
Good Luck
Old Nov 13, 2004 | 02:52 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Damn Kai.
I guess it might be better to ask what do you not know about B series's.
Old Nov 13, 2004 | 04:05 PM
Kai's Avatar
Kai
Rotorphile.
The PR4 came in two flavors, OBD-0 and -1. The 92-93 RS/LS/LS-S/GS Integras did use a PR4.
Old Nov 13, 2004 | 04:36 PM
SlowRider's Avatar
SlowRider
How Does the Cable hook to my pedal in my car when I use the conversion kit..
Old Nov 13, 2004 | 10:35 PM
Civic2Scooby's Avatar
Civic2Scooby
it doesnt, it adds a bracket so that you convert your cable tranny to hydraulic using your slave cylinder and a different push pin attached to the clutch lever on the tranny. I can take some pics if ya like.
Old Nov 14, 2004 | 03:26 AM
SlowRider's Avatar
SlowRider
That would be great..So I use the slave cylendat from the D series Tranny.
Old Nov 14, 2004 | 09:12 AM
Civic2Scooby
yup...
