b18c1-88 accord LXI (need wireing harness)
Old Nov 6, 2004 | 11:45 AM
Legend_master's Avatar
Legend_master
Never fast enough member
Default b18c1-88 accord LXI (need wireing harness)
Ok so I have all the parts needed to do the swap except for the wireing harness. My question is since it is an obd0 car can I use the same obd0-obd1 harness that they use in the CRX or OBD0 Civics. I know i will have to run a wire for the vtec to work, but besides that will there have to be any other wires run for this to work. I have heard of people useing a pr3(I think that is the code, it comes from a jdm b16a powered CRX) ecu in a crx and it did not require any kind of harness would this also work in the application I want it for?
Thanks for any help
Old Nov 6, 2004 | 02:18 PM
ED9man's Avatar
ED9man
driver
this is not going to be fun
did you get the place racing mounts? I think they are the only company that makes them.
Old Nov 6, 2004 | 02:20 PM
ED9man's Avatar
ED9man
driver
3geez.com
good site for help.
Old Nov 6, 2004 | 03:35 PM
Legend_master
Yes I got the pri Axles, Shift Linkage, and motor mounts. I am going to use a cable tranny from a 92 integra and all I need now is the wireing. There are a couple of people with wireing harnesses on the 3geez site, but they want way to much money for those. I have been looking around and the pr3 ecu connectors looks almost Identical to the accord, but I have not seen them in person.
Old Nov 7, 2004 | 06:24 PM
Kai's Avatar
Kai
Rotorphile.
If you don't buy one, you'll have to adapt the harness yourself. I hope you have lots of free time and some really good wiring diagrams.
