Lsd?????????????
Old Nov 4, 2004 | 12:53 AM
Wilson's Avatar
Wilson
Default Lsd?????????????
GUYS! please sum one tell me the function of a LSD and whats the goods and bads abot it! yea! tell me all.... thanks: )
Old Nov 4, 2004 | 01:42 AM
Wilson's Avatar
Wilson
ANYONE?? HELP?
Old Nov 4, 2004 | 02:05 AM
Namek's Avatar
Namek
Helps keep equal distribution of torque to the wheels keeping one wheel from slipping or having to slip. I doubt there is a "bad" thing about having an LSD. There may be other advantages/uses but I dunno :dunno:
Old Nov 4, 2004 | 02:17 AM
Wilson's Avatar
Wilson
IS TAHT IT?? oh, i thought it was more than that!
thanks neways dude
oh, wot happens to two same bhp/torque cars. one with lsd, and one without?
Old Nov 4, 2004 | 02:27 AM
Namek's Avatar
Namek
Well I suppose the one with LSD would just have more traction and put a little more power to the ground.
Old Nov 4, 2004 | 06:27 AM
LateApex's Avatar
LateApex
Track Day Club
Generally speaking, you have three basic types of differential, open, limited slip and locked.
With an "open" diff, if one tire loses traction and spins, the engine will send all of it's power to the wheel that sliping and none to the tire that actually has enough traction to propel the car. So, if you have RWD and your left-rear is sitting in oil, you can hit the gas hard and spin the left-rear without any forward movement.
A limited slip design, either through gears or clutches, redistributes some of the power to the non-slipping wheel. Accordingly, as in the example above, the right-rear tire will receive power and the car will move in the direction of tire rotation.
Properly designed and properly tuned, limited slip in 1, 1.5 or 2 way design allows you to apply more power more effectively when you drive through a corner.
With a locked differential, both the inside and outside wheels will move at the same speed.
