wiring harness
Old Oct 22, 2004 | 11:42 AM
B20powered's Avatar
B20powered
You can't see me
Default wiring harness
First off im using a friends name to post I dont have time to set one up my self. I have a 90si CRX and I have a built B20vtec. What wiring harness will I need to use? The stock Si(modified)?? I dont know. I'm running an OBD0 dizzy, Also what ECU should I be running?? My engine is ready to drop in I just need these things to complete it.
Old Oct 24, 2004 | 07:40 AM
B20powered's Avatar
B20powered
You can't see me
Nobody knows what harness I'll need?? Please I need to get my car finished. Do I just Modify my stock CRX SI harness???????
Old Oct 24, 2004 | 08:21 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
What harness you need depends on what ECU your going to use? I'm assuming your planning to use an OBD 0/pre OBD first gen B16A ECU. In that case, you the CRX Si harness and modify it to include the addition sensors and VTEC requirements.
Old Oct 24, 2004 | 10:10 AM
B20powered's Avatar
B20powered
You can't see me
What parts of my harness will I have to rewire? This is my grey part in doing swaps. I hate electric work.
Old Nov 17, 2004 | 09:07 PM
crxresurrect's Avatar
crxresurrect
Default harness
you harness should work your crx si is obd0 and if you are using a b16 ecu that is a pr3 obd0 then it should work you will have to order the 4 pc harness from hasport for the vtec sol,vtec oil pressure, 2nd o2 sensor, knock sensor. Let me know if that helps
