Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   Engine Swaps, Tech & Tuning (https://www.honda-acura.net/forums/engine-swaps-tech-and-tuning-33/)
-   -   just went h22...got some q's? (https://www.honda-acura.net/forums/engine-swaps-tech-and-tuning/156392-just-went-h22-got-some-qs.html)
vtecinside Sep 17, 2004 06:21 AM
Hey I just went h22 in my 94 accord with an auto to manual swap.
I know the redline is spposed to be 7200....yet I'm hitting fuel cut off at the accord redline of 6200.....what's doing this? ECU issues?
My ABS is out now...any reason that is swap related?
I also noticed that at 60 mph in 5th gear I'm cruising at ~3000 rpm and 80 mph is about 4000 rpm...are these typical for an h22? Or is my gearing screwed up?
appreciate any help....
the car is going back to the shop next weekend...so i just want to know what to expect.....
noel :cool:
sleepersol Sep 17, 2004 08:36 AM
did you swap out the ECU when you did the swap. If you rewired the stock accord ecu then that is your problem. Gearing sounds about right. The h22 5th gear has a near 2:1 ratio so you are doing 60 at 3K, 80 at 4K and so on
© 2026 MH Sub I, LLC dba Internet Brands
