2000 MDX Unexplained Vibration
Old Sep 7, 2004 | 09:30 AM
cburt's Avatar
cburt
Default 2000 MDX Unexplained Vibration
I'm getting a vibration whenever I step on the accelerator. The vibration stops as soon as I let off. The vibration is more apparant at higher speeds. Any thoughts?
Old Sep 7, 2004 | 10:10 AM
shivers's Avatar
shivers
Moderator Alumni
Do you get the vibration when you press on the gas pedal when the vehicle is stopped? If it only happens when you're moving, you may have a wheel out of balance or the alignment may be off.
2005 s2000
Old Sep 7, 2004 | 10:31 AM
cburt's Avatar
cburt
I'll check tonight if it still happens when the vehicle is stopped. My first thought was the balance or alignment. However, I can be going 55 with the pedal pressed and it vibs. Once i take my foot off the pedal it stops. I would think it would still vib...
Old Sep 7, 2004 | 12:15 PM
cburt's Avatar
cburt
Checked.... It does not vibrate when the vehicle is stopped??? Would balance or alignment vibs occur when your foot was on the pedal but not occur when you foot was off?
