The second gear conspiracy
Old Sep 4, 2004 | 10:51 AM
beier's Avatar
beier
A Philanthropical Fruit
Default The second gear conspiracy
Most amazing article ever. Talks about 0-60's times and Conspiracies involved in them. Haha really interesting if you have time to read it. I'm goanna paste it in.
( http://www.sportcompactcarweb.com/ed..._technobabble/ )
--start of article--
Technobabble: November 2001
By Dave Coleman
Car magazines are screwing you. All of you. Not only did you have to cut loose some pocket change to read this swill, but your car is actually slower because of this magazine and the hundreds like it around the world. Like so many conspiracies, this one wasn't exactly planned, and, in fact, not all parties involved have been aware of the big picture, but the fact still remains: Your car has been compromised.
I first noticed a pattern when creating a chart of horsepower vs. speed to compare a modified 200SX SE-R and a stock Integra Type R many years ago. Despite the fact the SE-R redlined at 6500 rpm and the Type R revved to 8000, both cars were geared to shift from second to third gear at a hair over 60 mph. Coincidence? Perhaps not. In the course of testing dozens of cars over the next several months, it became clear that the vast majority of cars require the 2-3 shift at just over 60 mph.
Conspiracy? Alien influence? Office politics?
Perhaps it's the latter.
When a powertrain engineering team starts work on a car, it doesn't head out blindly trying to make it "good," it is assigned hard performance targets, one of which is the 0-to-60 time.
Why?
Because magazines, enthusiasts and consumers harp on it, that's why. The 0-to-60 mph benchmark is so irreversibly ingrained in automotive culture that, more often than not, the 0- to-60 mph benchmark takes precedence over driveability, quarter-mile time, or real-world performance. Even the fastest second to third gearchange will add 0.2 to 0.3 seconds to the 0-to-60 mph time, so most powertrain engineers ensure this shift happens after the car passes 60 mph. In most cases, the rev limiter won't cut the fun until just a hair past 62 mph, or 100 kph, which happens to be the benchmark speed in metric countries.
(These acceleration curves pulled from our testing data over the last year. Each flat spot in the acceleration curve is a gear shift. What are the odds that cars as different as a 1993 Honda Civic EX and a 2001 Mitsubishi Lancer EVO VII would shift into third gear at exactly the same speed? The fact that four cars as different as these all hit second gear at the same time is sure proof of a conspiracy.)
So what's the big deal? What's wrong with optimizing gear ratios for our little tests? To grasp the full extent of this compromise, you must first understand what gearing does. A bicycle is a perfect place to start with this explanation, because most people have figured out bicycle gearing by landing on their ass.
This will all make sense in a second.
Imagine you're pedaling your bike in its tallest gear, with the chain on the biggest chainring in the front, and the smallest sprocket in the rear. A typical big chainring has about 44 teeth, while the smallest rear sprockets run around 11 teeth. For every turn of the crank, you move 44 chain links which, in turn, rotate the rear sprocket four times. Put another way, you only have to crank your feet through a quarter turn to turn the wheel once. This is a simple, 0.25:1 gear ratio.
Now, let's say you pedal with about 100 lb-ft of torque (if you can push down on a 7-inch crank with about 170 pounds of force, you can make 100 lb-ft of torque). At the rear wheel, that torque is reduced to 25 lb-ft because of the 0.25:1 gear ratio. Shift down to the lowest gear and you'll end up with something like 22 teeth in the front, and as many as 34 teeth in the rear. Your gear ratio is now 34/22, or 1.55:1. Instead of 25 lb-ft at the rear wheel, you now have 155.
With all that torque, you do a wheelie, fall off the bike, and walk home with a bruised bum.
At the same time that torque is being multiplied, of course, rpm is being limited. You can't stay in that granny gear while you crank down a hill because you can't pedal fast enough. Eventually, you'll hit your own personal redline.
The gear teeth in a transmission work in exactly the same way as the sprockets on a bike, trading rpm for torque multiplication. The 130 lb-ft of torque belted out by an Integra Type R at 7500 rpm can be multiplied by the 3.23:1 first gear, and then again by the 4.40:1 final drive, to become a whopping 1,848 lb-ft of torque at the front axle. At the same time, of course, that 7500 rpm gets divided by the same gear ratios and ends up as a mere 528 rpm. Such is the compromise of gearing. If second gear is made tall enough to reach 62 mph on a low-torque engine like this, torque at the wheels, and thus acceleration, often suffers. The car may reach that 0 to 60 benchmark more quickly but not any other speed.
The big sacrifice comes when you have a powerband that suddenly changes at a certain point, such as the Celica GT-S' 2ZZ-GE engine. At 6000 rpm, the 2ZZ's output jumps an astonishing 25 hp. Since it has a six-speed transmission and an obvious need to keep the engine above 6000 rpm all the time, it seems only natural that all the gears would be short enough and close enough together to keep the engine in its powerband.
Unfortunately, the engineers' fear of the 2-3 shift forced them to spec first and second gear taller than they should be. So tall, in fact, that despite having an extra gear, the Celica's second gear is about the same as the Type R's. As a result, the engine falls out of its narrow powerband on the 1-2 shift and acceleration suffers.
The Celica is such a good example because it has a dramatic change in character in the middle of its powerband, but the compromise exists on other cars as well. The most dramatic illustration of what proper gearing can do for a car was the 1997 Subaru WRX RA STi we drove in the 1999 One Lap of America. Of the many WRX models available in Japan, the RA STi was designed not for bench racers, marketing people, or magazines, but for rallying. The RA's gearing was remarkably short; shift points were determined by the car's powerband, not by an arbitrary testing standard; and the result was acceleration that still had me in slack-jawed amazement even after living in the car for an entire week.
Imagine what your car could be like if it weren't for magazines...
--end---
ISN"T THAT AMAZING. Well it get kinda boring with all the explanations involved, but the concept was somewhat shocking. Never heard of that before. Hmph.
Old Sep 4, 2004 | 03:47 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Hey, good find.
-PHiZ
Old Sep 11, 2004 | 08:10 AM
atli126's Avatar
atli126
dam thats interesting, good read
Old Sep 11, 2004 | 08:19 AM
:eh: Makes u wonder doesnt it.
Old Sep 11, 2004 | 05:03 PM
ED9man's Avatar
ED9man
driver
My CRX won't hit 60 without a 2-3 upshift.
I think a quick shift is only good for a tenth of a second loss.
Old Sep 11, 2004 | 06:19 PM
supapoopa's Avatar
supapoopa
Nissan: Shift_Recall
sooo, my civic would be a beast if it weren't for those damn magazines. h:
Old Sep 12, 2004 | 12:19 PM
Kai's Avatar
Kai
Rotorphile.
By Dave Coleman
Damn, I remember reading that when it came out. Still a good article though.
Old Sep 13, 2004 | 09:22 AM
catatonic's Avatar
catatonic
(´Д`)
That seems like just yesterday...
