Turbo & Supercharger....
Old Aug 28, 2004 | 11:21 AM
99integra_gsr's Avatar
99integra_gsr
Default Turbo & Supercharger....
I have a 99 Integra GSR. The only things that have been done are cold air and fuel/air controller. It is a VTEC of course. Can A trubocharger and Supercharger be put on consecutively?
Old Aug 28, 2004 | 12:05 PM
MPerson's Avatar
MPerson
It's useless, what a bad idea. Never do it, think about getting one, not both. I'd opt for the turbo rather than the sc.
Old Aug 28, 2004 | 01:42 PM
kenton's Avatar
kenton
Change sig? Lose [quote]!
Unfortunately, JR superchargers are known to wear out over time, leak oil, crack, etcetera. Although, I've heard lots of good about them. I just know a stock SC isn't going to make the most power for you, although it may be easier than a custom turbo.
Old Aug 29, 2004 | 12:22 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
its has been done. In fact, its quite common on g1 mr2's (the call it "twincharged"). But its a complicated and often finicky combination... not exacltly what you'd call reliable. I've also never heard of the combination producing nearly as much power as a apropriately-sized turbo setup.
Old Sep 1, 2004 | 08:12 PM
gsr_da's Avatar
gsr_da
Go turbo-superchargers are less effecient than turbos, which means you cannot get as much boost from a supercharger than from a turbo. My advice is to do your homework on turbocharging and build your own kit-which will cost you around 1/3 of the price than if you bought a pre-fabbed kit.
