honda prelude white smoke from tailpipe
Old Jul 9, 2004 | 07:07 PM
brettybaby's Avatar
brettybaby
Default honda prelude white smoke from tailpipe
I have a 1993 honda prelude si h23
on a hott day if i use my car all day smoke will come out the tailpipe. it looks like white steam. i think its the water. and yea the water in the radiator gets low.
but there is no water in the oil i check and this problem only happened 3 times in the last 2 months. There was a ton of smoke though. and every time it happened when i used reverse on my 5speed. when i shifted to first the smoke stoped
any ideas
is it the water pump or like the head gasket?
Old Jul 10, 2004 | 06:04 PM
oscarhmoyano's Avatar
oscarhmoyano
Hi dear, well maybe (im not sure) but i had 2 times this problem ... 1 with my 3th gen lude and 2 with my ex-gf integra you may have 2 things,
1: Oil getting in your spark plugs (white, clean smoke)
2: Water Pump (white hot very hot smoke)
But in the way that you're telling (your wather going low) you may check your hoses or even make sure if it's really your water pump, when i had the smoke coming from under my car, it was a little hose that my mechanic charged me $30.00 to replace ,, (i was so paranoid thinking that i was going to spend 200 250 for the whater pump replacement , LOL
Oscar
Old Jul 10, 2004 | 06:05 PM
oscarhmoyano
water LOL
Old Jul 12, 2004 | 02:14 AM
Kai's Avatar
Kai
Rotorphile.
It's a bad head gasket. The engine is not hot enough at start-up to burn coolant off the block (as in an external leak.)
Old Jul 21, 2004 | 10:17 AM
civicsirnos's Avatar
civicsirnos
overheated lately? shrink the head gasket and pow -- white smoke from water
