used flywheel????
Old Aug 9, 2002 | 04:01 PM
paz92ls's Avatar
paz92ls
Default used flywheel????
ok. whats the general consensus on used flywheels; specifically 18000mile type r flywheels.(never been resurfaced/shaved/anything)
if it can be had for cheap -should it be had??
(ps to go on 92 b18a)
thanks in advance.
paz.
Old Aug 9, 2002 | 07:10 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
The R flywheel is lighter, so it would definitely be worthwhile if you could get it for cheap. I would still resurface prior to putting it on though.
Old Aug 10, 2002 | 06:48 AM
paz92ls's Avatar
paz92ls
of course id resurface it if i got it. but my point is-it should be fine(having only 18000miles and never yet been resurfaced) right? right?
Old Aug 10, 2002 | 03:07 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Unless it was abused for those 18K, it should be fine.
Old Aug 10, 2002 | 04:41 PM
TheRooster's Avatar
TheRooster
Former Senior Member
Resurface and balance it, and you should be fine
Old Aug 10, 2002 | 09:28 PM
GimpyAccord's Avatar
GimpyAccord
if you have the tools to do it... check its runout.. might be a reason hes dumping it
Old Aug 10, 2002 | 11:06 PM
paz92ls's Avatar
paz92ls
oooh. good point my man. now... that would be thickness? or what?runout?
Old Aug 11, 2002 | 09:55 AM
GimpyAccord
basically you need equipment to do it.. BUT its the same principle as checking a brake rotor.
you spin the rotor or flywheel using a micrometer and check its runout.. the deviation of the surface (warp).
machine shop could do it... but at that point you own it anyway :thumbup:
ENFORCER
10
Aug 7, 2008 07:22 PM
OzWolfbane
Engine Swaps, Tech & Tuning
Jan 1, 2005 06:18 PM
85hatch
CRX & Pre 92 Civic
2
Sep 10, 2004 11:20 AM
