B16A SiRII into a 93 Civic EX coupe
Old Jun 15, 2004 | 11:14 AM
come_see_my_pjs's Avatar
come_see_my_pjs
Default B16A SiRII into a 93 Civic EX coupe
I have a 1993 Civic Ex coupe, D16Z6. I have bought a B16A SiRII engine that I want to put in, does the wiring harness require any modification or is just plug and play. I have the new ECU for the B16. Anything else you might foresee being a problem please let me know, thanks.
Old Jun 15, 2004 | 10:20 PM
Civic2Scooby's Avatar
Civic2Scooby
what else do you have purchased for it such as mounts, linkage, tranny bracket, etc etc....make a list of what you do have so that we can add on the things your are missing :goodjob:
Old Jun 16, 2004 | 09:05 AM
PHiZ's Avatar
PHiZ
BOOST GOD
is this car also know as the CVCC ? If so, when doing searches, use that, it comes up with a lot more info.
here and on honda-tech.
-PHiZ
Old Jun 16, 2004 | 02:39 PM
come_see_my_pjs
I've got the ecu for the new engine, b series shift linkage, integra type R axles, half shaft, and all the sensors and mounts are intact on the new engine.
Old Jun 16, 2004 | 02:42 PM
come_see_my_pjs
why would my car be refered to as a controlled vortex combustion chamber?
Old Jun 16, 2004 | 08:05 PM
PHiZ's Avatar
PHiZ
BOOST GOD
From what I understand, the CVCC technology, was basically staggered opening of the intake valves to promote swirling in the cylinder, and better combustion of the mixture.
I know of several threads of ppl wanting to swap motors into some classic hondas. But I can't remember what chassis they were, only the CVCC designation.
I know I participated on one conversation here, and on honda-tech.
As far as buying shift linkages. I have no reason to believe they will be the right length, and you'll most likely end up having to customize them. I hope you got a good price.
-PHiZ
Old Jun 16, 2004 | 10:48 PM
come_see_my_pjs
my honda is a classic honda? umm, thats news to me... and i know the shift linkage is the right length. i just need to know about the ECU connections, anyone that has done the swap should be able to tell me, thanks.
Old Jun 16, 2004 | 11:09 PM
Civic2Scooby
I would use GSR axles not type R...I believe they have a different spline pattern in the hub than the civic hubs.
ecu connections can be found in the online resources stick in the civic/del sol forum
Old Jun 17, 2004 | 09:33 AM
PHiZ's Avatar
PHiZ
BOOST GOD
I have no idea how. But I responded to the wrong thread. Some guy was trying to do a swap on a '70s or '80s civic "1700"
Wow, I have no idea how that happened.
-PHiZ
maverick77
Sep 26, 2004 05:53 PM
EJ8_coupe
Showroom
71
Mar 13, 2004 10:48 AM
cheapcarparts
Feb 8, 2004 02:10 PM
