vacuum/idle situation on ls swap
Old May 23, 2004 | 09:47 PM
slammed91-hatch's Avatar
slammed91-hatch
Default vacuum/idle situation on ls swap
I have a obd0 ls motor in my 91 civic si hatch. It's in and starts, but it runs weird. The idle bounces in rpm like a constant steady bounce up and down. I get a code 14, which is eacv. How do i fix this. I pulled the eacv off to check it out and it didn't appear to be clogged or anything like that. Someone please help, this is all that's holding me back from getting my new swapped hatch on the streets.
Old May 23, 2004 | 10:18 PM
Civic2Scooby's Avatar
Civic2Scooby
take off your iacv or eacv or whatever the hell you want to call it, and spray the shit out of it with some good ole carb cleaner, making sure to clean the screen very very well. if this does not work, then it means you have a bad iacv, or you have plugged in the wrong plug to the iacv.
Old May 24, 2004 | 05:10 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
with the car running and idling weird. removed the connector from the IACV. If the the idle levels off, you have found your problem. Remove the IACV and clean it as stated above.
You can also replace the IACV. From honda it's not the cheapest thing, but you can find used ones on the web easily.
www.sohfast.com
Project EVA - The Track Package
Project EVA
Old May 24, 2004 | 05:45 AM
Running925's Avatar
Running925
Your Powder Coater
I have an extra one that you could probly have.. as soon as i fire up my swap & know that my current one is good i'd be willing to ship you my extra one!
Old May 24, 2004 | 11:07 AM
slammed91-hatch
sweet, my e-mail is bubbiemellum@yahoo.com. Let me know if you can send it. I will pay shipping of course. also, i have tried unplugging the wires to it while it's running, it makes no difference.
Old May 24, 2004 | 11:45 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
then i don't think it's the IACV. look at the throttle adjustment, and try to locate leaks in the vacuum lines. i would almost just start replacing lines and keep going.
Project EVA
Old May 25, 2004 | 06:55 PM
slammed91-hatch
alright, i took the eacv off of the intake manifold and started the car, it definetely runs weird with it off. I don't know if this means anything. also will someone explain what the eacv does? I thought i had an idea, but i didn't know that coolant went through it, now i'm way confused on what this even does.
Old May 26, 2004 | 12:14 AM
Civic2Scooby
I would prob. take a look at the fast idle valve over the IACV if you unplugged it, and it made no difference.
95integrajdmh22
Engine Swaps, Tech & Tuning
2
Feb 27, 2004 04:42 PM
Jafro
92+ Civic/EL & Del Sol
56
Nov 4, 2003 06:11 PM
qt performance
Apr 16, 2003 04:07 PM
KingPin
6
Nov 18, 2002 12:23 PM
Colt45
2
Sep 4, 2002 10:17 AM
