h22 into 94 accord?
Old Aug 2, 2002 | 05:49 AM
dominion03's Avatar
dominion03
Default h22 into 94 accord?
hey guys i have a 94 acccord 4dr DX. i have some money saved up and i was thinkin about doin the h22 swap. if i do this which one should i go with? usdm or jdm? i know the jdm has more power, which is definately better!, but does it pass emissions? i want a daily driver so this is a must. i live in Atlanta so if anyone could help mke out i'd appreciate it!
also...if i go with the swap...what else should i do?
thanks to all who reply
dominion03
Old Aug 2, 2002 | 06:42 AM
white lightnin's Avatar
white lightnin
Im from Atlanta so hit me up if you want some help. I have a friend currently swapping an h22a into a 97 accord. Ive never done this swap myself but I doubt it would be that tough to do it yourself. USDM will most probably be easier on wiring. Ill do some research and get back to you.
Old Aug 2, 2002 | 06:46 AM
daviid's Avatar
daviid
From: Concord, NC ( Originally Berlin, CT & Southington, CT )
it will pass emissions. when you get it defintly replace the timing belt and water pump
Old Aug 2, 2002 | 06:47 AM
white lightnin
Ok I went to h22a.org and foudn some info. Basically you use all the prelude sensors, prelude brackets to bolt up accesories, the accord axles, power steering lines from both cars, prelude throttle cable, accord shift and clutch linkages, and all the accord mounts except for the drivers side. Doestn seem too bad to me.
Wiring looks a bit tough though. Here is the link:
http://www.h22a.org/5gswap.htm
Old Aug 2, 2002 | 07:07 AM
daviid's Avatar
daviid
send me a msg on aim @ JDMMotorsDirect when you are ready to buy and ill see what i can do for you
Old Aug 2, 2002 | 07:38 PM
dominion03's Avatar
dominion03
Thanks guys...the help is really appreciated!!!
h22civ
Sep 28, 2006 06:16 AM
h22civ
Mar 7, 2006 10:48 AM
jtelliso
Prelude
Feb 19, 2006 05:45 PM
VoteNader
Prelude
4
Apr 6, 2005 08:44 PM
accordtypeslow
Oct 7, 2003 01:50 PM
