Question about B20B swap
Old Mar 14, 2004 | 07:09 PM
pirate252's Avatar
pirate252
Default Question about B20B swap
A car I am looking at has a B20B in it. It is a 91 Integra RS...
Are you suposed to leave the stock ECU in? Cuz he did and i am wondering if there are problems since the ECU in there is for a 1.8L engine with different compression than the 2L engine thats in there now running off the same ECU.
Thank
Old Mar 14, 2004 | 07:32 PM
pirate252's Avatar
pirate252
It is also throwing a code 43 (fuel system) code abouve 70MPH, could this be also related like it needs a bigger fuel pump, and fuel lines??
Old Mar 15, 2004 | 06:08 AM
pirate252's Avatar
pirate252
anyone?
Old Mar 15, 2004 | 06:24 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
the 2.0 liter is primarily a 1.8 just with a longer stroke.
you can probably get away with the stock ecu, but it always find it more useful to go with the ecu that the motor uses from the factory.
you shouldn't need a new fuel pump or anything with a b20b swap.
Any CEL would have to do with faulty install.
Hope I helped.
Project EVA - The Track Package
Project EVA
Old Mar 15, 2004 | 06:42 AM
pirate252's Avatar
pirate252
The CEL was happening before the swap, so he says, but he said everyone he asked about it told him it was the O2 sensor, does it sound like a O2 sensor to you?
Old Mar 15, 2004 | 06:45 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
I would presume if there was an issue with an 02 sensor you'd throw a code for the o2.
I could be wrong.
Project EVA
Old Mar 15, 2004 | 06:47 AM
pirate252's Avatar
pirate252
hmmmm...what would you suspect would throw a fuel system code then?? sine theres seperate codes for the injectors and stuff...its not those, i cant figure out what it could be, and i wanna figure it out before i buy it lol
thanks
95LudeSi
CRX & Pre 92 Civic
Aug 13, 2003 01:29 PM
Crazy_Phucker
92+ Civic/EL & Del Sol
2
Jul 27, 2003 03:44 PM
metalman
2
Dec 21, 2002 06:26 PM
StockDC2
Sep 27, 2002 06:03 AM
dubss
Jul 3, 2002 01:20 PM
