some Q's about swapping a B16A into my 1998 EX
I purchased a 96-98 JDM B16A SiR-II motor tonight. Its an OBD2 motor just like my car, and I already have VTEC wired in because its an EX, so i'm assuming the ECU and harness will plug right into my car with no modification right? If not, what modification(s) are needed? I can't seem to find clear answers on this anywhere...
the motor is out of JDM EK4 SiR-II (1996-1998) what is my Power Steering situation going to be? Can i use the stock Civic EX pump? Do i need to modify the lines? I read somewhere a 1996 Del Sol VTEC P/S bracket would work just fine, is this true? What could i us from 99-00 SI? What about A/C? How do retain my A/C system? can i use my compressor or do i need one from 99-00 SI? thanks in advance for all the help. :) |
| All times are GMT -8. The time now is 08:43 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
