B17 = B16 Buildpath
Old Jul 31, 2002 | 07:25 PM
SuperSlow87's Avatar
SuperSlow87
H-A G/\|v|3R
Default B17 = B16 Buildpath
I was wondering, since the b17 seems to be a near copy of the b16 are the two similar enough to except the same parts. i.e. would a ITR header bolt up to a b17 since it can be fitted to a b16 head?
Also was the b17 a US only engine and why do some people say it excepts boost well? I remember Mr.Fatbooty making that comment once altough I could be mistaken.
Old Jul 31, 2002 | 09:43 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Yup, an ITR header should bolt right up, same bolt pattern. Any stock B series Honda engine can respond well to reasonable amounts of boost. I would say 8lbs of boost should be perfectly fine on a stock engine, 12-15 if it's perfectly tuned
Old Aug 1, 2002 | 02:14 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
The B17 has a nice stroke length compared to the bore, and it's CR is in a nice comfortable range, couple that with available B16 head parts, and yes, it will accept boost pretty well.
-Harry
AIM: NDcissive
Old Aug 1, 2002 | 09:39 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
P... there you are... how come you are not on the civic forum anymore? hardly see you there. btw, this is rui... i use to have the name of onichi, but after ha went down... now i am back to junior member... tokyoracer... anyway... just wanna say what's up... and hopefully soon, i will get the rear disc brake from ur friend in sf... if it's cool with you, i'll pm you from time to time on how to install it... cuz running the brake line part is something i am not sure on doing.. don't know what tools are needed to disconnect the ebrake line. but just wanna to say wussup... :thumbup:
Old Aug 1, 2002 | 11:23 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
a basic socket set and a cheater bar were all I used to do the rear disc swap, let me know if you have any questions about it.
Old Aug 2, 2002 | 06:55 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The B17 is indeed a US-only motor. It was made in Japan but only sold in the '92-'93 GSR (G2 tegs with VTEC were called RSi and XSi in Japan and had a B16).
B16 and B17 heads are identical. They do indeed have the same part number cast into them.
People say the B17 takes to boost well because it starts out with a CR of 9.7:1 which provides for a bit less detonation. At this point any motor you get your hands on will be 9-10 years old. I would be hesitant to just slap on any sort of forced induction setup without doing a rebuild on the motor first.
Old Aug 3, 2002 | 07:42 AM
SuperSlow87
H-A G/\|v|3R
Thank you for all the replies, its good that the B17 has an identical head and such similar characteristics as the B16, makes things a bit simpler. Two more questions, does the G2 have the same suspension setup as the G3 Integra and the engine gasket kit for a B series is what... around 1k right?
Old Aug 3, 2002 | 10:38 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Second Gen and third Gen Integra Suspensions are different. You might be able to interchange the springs(although I'm not too sure about that), but the dampers are different part numbers.
Old Mar 17, 2003 | 08:10 AM
rlschi36's Avatar
rlschi36
For Mr. Fatbooty,
I just bought a 92" GSR with the old B17 engine. I was thinking about bolting on an AEM induction set-up. You stated that the engine should be "re-built" first. What does this
"rebuild" involve?
Old Mar 17, 2003 | 11:10 AM
civicon19s's Avatar
civicon19s
You are just slapping on an intake...that doesnt apply to you. He was talking about boosting with a turbo or supercharger. "Building" involves replacing or refinishing/checking everything in the motor... pistons, rods, crank, bearings, etc..
