Is it safe to remove my CAT converter??
Old Feb 22, 2004 | 11:21 PM
workman92's Avatar
workman92
snow and ice driver
Default Is it safe to remove my CAT converter??
I have a 92 si hb and I have no air care or anything like that for at least 8 hours from where I live so is there any side effects of removing my CAT?
I have a Ractive Intake and an OBX ReaR mUFFLER and everything else is all stock like new. I heard the valves need the Cat for some reason and that it makes the car run alot differnt if you remove the Cat.
Any help is great
THANKS
Old Feb 23, 2004 | 09:03 AM
qtiger's Avatar
qtiger
Your car will be louder and smellier, but other than that nothing will go wrong.
Honestly though, you won't gain any horsepower unless your cat is clogged up. Probably not even worth your time.
Old Mar 13, 2004 | 02:05 PM
Splishkanake's Avatar
Splishkanake
JDM PWR
You will notice a loss in torque, but increase in Hp. You will only notice the Hp on the freeway, you 70 to 120 mph will be better. But pretty much pointless to do. But if you remove it, and run some straight pipe out to a muffler it will sound nice
Old Mar 13, 2004 | 02:07 PM
Splishkanake
JDM PWR
The reason it runs different is because is reduces back pressure, which does build HP, but engines need certain amounts of back pressure in order to run effciently.
Old Mar 14, 2004 | 01:35 PM
TheRooster's Avatar
TheRooster
Former Senior Member
Your idle won't be as smooth, and decellerating will feel realllllly weird. I run a racing cat, sometimes, and notice that to be a major problem. Like was said though, you don't gain anything from removing it (I run the racing cat on the track because it's the only thing non-custom that fits my 2.5" collector) and if you do run it, it's really good for the environment. Your engine will also run better with it in, as your ecm will run closed loop, instead of dumping fuel because it thinks your O2 sensor is shot.
Old Mar 14, 2004 | 02:56 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Removing the cat will improve exhaust flow.
However the engine only needs so much exhaust flow capacity before it starts to not make any more power from increased flow. Might as well keep a cat.
Your stock cat however, probably is clogged up from being so old. You should replace it with a high flow unit. Practically speaking, it'll make just as much power as not having a cat, and you won't be spewing raw exhaust into the atmosphere.
Old Mar 16, 2004 | 11:15 AM
phantom_sol's Avatar
phantom_sol
1 4m 73h 5700p1d
sure its safe, but is it legal? :P
removing a cat can really free things up as far as restriction. what good is your 2.5" exhaust on a bottlenecking cat? but theres a give and take for this. off the line you might suffer because there is no low end back pressure. but high end will gain because there is a lot less restriction. why get rid of a cat completely? get the best of both worlds with a decent high flow cat. still retains some backpressure but flows a lot better than stocks. just my 1/50th of a dollar
Old Mar 16, 2004 | 02:46 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
But...
A 2.5" exhaust isn't going to help anything on a basically stock D16.
94HybridLX
Accord
Feb 10, 2004 03:42 AM
95tegRS
19
Jun 22, 2003 05:46 PM
kchubb
92+ Civic/EL & Del Sol
5
Feb 24, 2003 02:04 PM
ZiviCase10287
CRX & Pre 92 Civic
2
Feb 8, 2003 08:13 PM
RKV
Accord
12
Aug 7, 2002 03:57 PM
