Apexi V AFC-II Or Apexi S AFC-II
Old Jan 11, 2004 | 07:09 PM
MGD Teg's Avatar
MGD Teg
Default Apexi V AFC-II Or Apexi S AFC-II
I was curious about these 2 controllers.
**(Apexi V AFC-II Or Apexi S AFC-II)
-What is the Difference?
-Which is better?
These controllers are about the same Price, and I was about to buy one, when I became confused after seeing one another.
Its for my Teg. (Need mostly for my fuel/air ratio)
Gsr/ Aftermarket everything, Internals and all.
Thank u:thumbup:
Old Jan 11, 2004 | 10:13 PM
qtiger's Avatar
qtiger
VAFC controls VTEC.
SAFC doesn't.
Old Jan 12, 2004 | 12:07 AM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
Super airflow converter vs. VTEC airflow converter
u wouldn't need a SAFC if ur setup isn't gonna be dyno tuned
same goes for VAFC, so if u don't drive a Honda VTEC don't get one
all it does is control VTEC high-low\low-high engaement points by modified pressure sensors and ECU readings
no gains really, the factory X-over point is adaquate unless u have some major mods and are planning a timing change\dyno tuning
Old Jan 12, 2004 | 12:16 PM
27Sec-Type-R's Avatar
27Sec-Type-R
Well for one, He says he has a Teg (Integra maybe?)
Second At the bottom he mentions Gsr/ with Aftermarket Everything (Internals)
Last he asks if it would help his air/fuel.
I'm guessing to Lean out or Richen.
Old Jan 13, 2004 | 07:54 AM
Kai's Avatar
Kai
Rotorphile.
The VAFC is made for use by the Honda/Acura crowd. Not only does it have a VTEC controller built in, but it comes preconfigured for use with a Honda speed-density fuel injection system.
The SAFC is the same thing without a VTEC controller that can be used on pretty much any fuel injected car and is reconfigurable to different FI systems. I would use an SAFC on my car to be compatible with my MAF type fuel injecion system.
If you have time to dyno tune the thing, gains of 5-10 horsepower wouldn't suprise me.
