EGT Gauge and sensor senders
Old Dec 10, 2003 | 07:59 AM
Hammer3211's Avatar
Hammer3211
passinUup
Default EGT Gauge and sensor senders
Im trying to buy an exaust gas temperature gauge. found a good price on one. but along with purchasing it you must pick a sender. ive called around and ive been getting mixed messages. saying i can use my OEM oxygen sensor, or i have to buy a aftermarket sensor/sender. ive been researching it as well and i cant figure it out. i get the same information on the internet as well as back at home in md. if u hav information on the subject please let me know
thanks
its for my 95 civic/del sol ex
Is there a phone number or anything i can get and ask the question. can any one redirect my problem
Old Dec 10, 2003 | 10:33 AM
PHiZ's Avatar
PHiZ
BOOST GOD
Are you talking about an EGT probe, or a Wideband O2 sensor?
-PHiZ
Old Dec 11, 2003 | 10:52 AM
PHiZ's Avatar
PHiZ
BOOST GOD
wow, in response to your PM.
A wideband O2 sensor is like the stock O2 sensor, except much more accurate and robust. It measures the ratio of air to fuel. It has an O2 sensor that looks like it's stock, but this goes to some sort of control unit and/or display.
And EGT probe, meansures the temperature of the gases coming out of the cylinder.
They are two completely seperate things.
-PHiZ
Old Dec 11, 2003 | 12:44 PM
Hammer3211's Avatar
Hammer3211
passinUup
what should i get then. if im installing the air/fuel ratio gauge and the EGT gauge. and which ever one i am suggested to get. where would it go. in the same threaded hole as the OEM O2 sensor. jus swap them out.
