Wiring Harness Question?
Old Nov 26, 2003 | 09:10 AM
Mr. UnderHill's Avatar
Mr. UnderHill
Love Is Suicide
Default Wiring Harness Question?
I'm pretty much done with my project, It's an LS-Vtec in a 89 Civ 4-door. I've been getting conflicting reports on the wiring harness I need. Being that it's dual point fuel injection, I need a wiring harness from a Crx or Hatchback Si. Or can I modify my stock harness? Any help will be much appreciated.
Old Nov 26, 2003 | 09:47 AM
PHiZ's Avatar
PHiZ
BOOST GOD
what ECU are you trying to run?
DPFI->MPFI conversions arent' that bad. Look at the wire colors on a MPFI car. There are four wires with each a different color, corresponding to inj1, inj2, inj3, inj4. And a shared 12v source (yel/blk I think).
So, your inj1 and inj2 are already wired. You need 2 wires to the ECU (inj3 and inj4). And then 2 wires to the shared 12v rail, at the resistor box...
Do take special consideration, to make sure that the proper injector number is going to proper cylinder...
What ECU?
-PHiZ
Old Nov 26, 2003 | 09:50 AM
Mr. UnderHill
Love Is Suicide
Thanks man......It's a pr4 ecu.:thumbup:
Old Nov 26, 2003 | 11:30 AM
PHiZ's Avatar
PHiZ
BOOST GOD
hehe, of course it would be that one. I only say that because there are OBD0 and OBD1 PR4's hehe. Neither of them will activate vtec, so how are you addressing that?
Which PR4, OBD0 or OBD1?
http://hondata.com/techecuid.html
-PHiZ
