b16a3
Old Nov 25, 2003 | 07:33 PM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
Default b16a3
I have asked this before in the integra Forum, but it is really urgent so I think I would get some more response to it here.
I got a GS-R with a b16a3 in it, and my check engine light is on because of a code 54 the ECU is throwing.
Bad or Missing CKF Sensor (Crankshaft Fluctuation Sensor)
Well the problem is, my mechanic said there was no sensor, there was no place to put it on the b16a3, no hole for it, no wire for it from the engine. Is it true that the b16a3 has no CKF-Sensor?
Old Nov 25, 2003 | 10:45 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Hi, I got your PM, but I'll just answer here, because you have the info I requested in PM.
CKF is a new sensor for OBD2, from what I understand it judges misfires, by measuring rate of change of crank. On the OBD2 motors it lives on the oil pump.
OBD1 motors didn't have this sensor.
Sounds like you're running an OBD2 ecu (if it's still the GSR ecu, that's a poor choice).
Solution 1: But a ecu conversion harness and OBD1 P28/P30
Solution 2: Replace your OBD1 oil pump with and OBD2 one, and run the appropriate wires.
-PHiZ
Old Nov 26, 2003 | 12:48 AM
qtiger's Avatar
qtiger
Originally posted by PHiZ
Sounds like you're running and OBD1 ecu (if it's still the GSR ecu, that's a poor choice).
I think you mean OBD2.
Old Nov 26, 2003 | 08:31 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
I think you should go with Phiz's soulution number one :thumbup:
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Nov 26, 2003 | 09:42 AM
PHiZ's Avatar
PHiZ
BOOST GOD
Yup, thanks for catching that. I'm editing the post for clarity.
-PHiZ
