pistons and WD40
Old Oct 28, 2003 | 01:28 PM
SRD_DC2's Avatar
SRD_DC2
Default pistons and WD40
I was watching my freind install his new ctr pistons into his b16a2. Before he put the pistons in, I noticed he sprayed wd40 all over the cyclinder walls and the pistons. I dont have much knowledge on installing pistons, but is this okay?
Old Oct 28, 2003 | 04:17 PM
Snoopy's Avatar
Snoopy
been there done that
it helps lubricate the cylinder walls and pistons, making them easier to slide in
Old Nov 11, 2003 | 04:33 PM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
It also helps the rings to seat.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Nov 11, 2003 | 11:51 PM
S2Kev's Avatar
S2Kev
I would've just used regular conventional oil. That's what you're suppose to use anyway when you prime the engine.
Old Nov 13, 2003 | 09:45 AM
sphinx054's Avatar
sphinx054
im with e30dood i would use assembly lube on the pistons and just some motor oil on the cylinder walls. you cant really put too much lube on before that first startup your car will have the most ware in the first 30 secs than in its lifetime if not properly lubricated. but anyway im not sure that WD40 is bad but im sure that there better ideas than that.
Old Nov 13, 2003 | 01:26 PM
AwwsChwA's Avatar
AwwsChwA
When I put my engine together I dunked the pistons top-first into 30W oil and worked it into the rings one at a time. I used tons of assembly lube putting the rods/crank together.
One important thing to remember when youre building an engine is, when it's ready to be started, crank the engine over for about 30 seconds with the spark plugs out. This primes the oil pump and gets the oil up into all the passages. Makes that first start up much more gentle.
