Valve Adjustment
Old Jul 20, 2002 | 09:24 AM
Accordlxcpe97's Avatar
Accordlxcpe97
The Krazy One
Default Valve Adjustment
I searched the forums and did not find much on vavle adjusting. Anyone know of a detailed "how-to" on valve adjusting. Keep in mind I am a noob. Pictures help. I want to adjust the valves on an F22b2.
Old Jul 20, 2002 | 10:04 AM
DB7 2.0's Avatar
DB7 2.0
Banned
i used to have a 95 Accord 4cyl too... if you want i can see if i still have the service manual for it, if you want, ill sell it to you for like $10 shipped but i gotta find it first.
Old Jul 20, 2002 | 10:07 AM
Accordlxcpe97
The Krazy One
That would be cool, let me know if you find it.
Old Jul 20, 2002 | 01:06 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
You need a 10mm wrench, flat tip screwdriver, feeler guages, and just rotate each cylinder either with the key with the coil disconnected from the distributor, or a socket on the crank to get each cylinder to top dead center, where you can set your valve lashes to factory specs. Just take off the valve cover, look around, and it will make sense. Also be sure to go easy on the valve cover nuts when putting it back on, a little tight is ok, too tight is snapping stuff off, go just tight enough to not be able to spin it back off by finger.
-Harry
AIM: NDcissive
Old Jul 21, 2002 | 01:19 PM
Accordlxcpe97
The Krazy One
Thanks for the info. How hard is it to turn the crank? Is there a specific torque setting for the adjustment screws and vavle cover bolts?
Old Jul 21, 2002 | 02:59 PM
1stGenCRXer
Torque specs- tight enough, but not ham-fisted. between 5 and 8 lb-ft if you feel the need to use a torque wrench.
Crank is easy to turn over if you take out the spark plugs.
Old Jul 23, 2002 | 08:44 AM
Accordlxcpe97
The Krazy One
Thanks for all the info!
n33lu
Accord
11
Mar 24, 2003 01:50 PM
oc_civic
92+ Civic/EL & Del Sol
6
Jun 24, 2002 10:21 AM
oc_civic
Engine Swaps, Tech & Tuning
2
Jun 24, 2002 06:59 AM
vtec2000
6
Jun 21, 2002 08:51 AM
