Coolant Thermostat Location 96 Integra
Old Oct 10, 2003 | 06:20 AM
Resistance's Avatar
Resistance
Default Coolant Thermostat Location 96 Integra
Hi to all from a new user! I would like you to tell me where I can locate the Coolant Thermostat on my 96 Integra. As per Autozone.com - its located at UNDER HOOD, CENTER, FRONT ENGINE AREA, ABOVE EXHAUST MANIFOLD, MOUNTED IN CYLINDER HEAD - I could not locate it. I will appriciate any help you can offer.
Old Oct 10, 2003 | 07:40 AM
JimBlake's Avatar
JimBlake
They got that wrong... Honda likes to put the thermostat in the LOWER radiator hose. Follow the lower hose back to the engine, that's where the thermostat is. The T-stat housing is kinda behind/beneath the distributor. It'll be easier to get to if you remove the intake air pipe.
Old Oct 13, 2003 | 06:53 AM
Resistance's Avatar
Resistance
Thanks. I tried looking for it, could not find it still.
Old Oct 13, 2003 | 08:25 AM
JimBlake's Avatar
JimBlake
Well, I didn't think they moved it between '95 & '96???
The t-stat housing is located right where the lower hose attaches to the engine. The aluminum part that looks kinda like a big hose nipple is the t-stat housing. The t-stat is inside there, located right where the housing splits apart.
