Drag Strip From the staging lanes to the finish line, this is the spot for on-track drag racing discussion.
My Drag PY ITR
Old Oct 16, 2009 | 01:04 PM
TheAddict's Avatar
TheAddict
Default My Drag PY ITR
Well, I'm a relatively new member on this site, but I figured since I'm into drag racing, I'd post my car up. A couple of them are a bit older, but the most recent are the ones with the front mounted SC-72. It's not 100% together at the moment, just got done pulling it apart and putting it back together. So excuse the mess of plug wires.
Mods:
Darton Sleeved 85mm LS block
9.5:1 Custom JE pistons w/ thicker wrist pins
Custom BME Aluminum connecting rods
Knife edged and lightened LS crank
ARP mainstuds
O-ringed
-- Custom AA Race cylinder head
Supertech valvetrain
custom grind cams
JG intake manifold w/ custom lower fuel rail
8-1600cc injectors
Kinsler mechanical fuel pump
Twin-12 rails
Borgwarner SC-72
AA custom made front mount turbo manifold
AA custom 3.5" charge pipe and WG dump
custom fuel cell
Kinsler K140 FPR
2 more fuel injectors on the lower IC piping for cooling
There is a lot I'm forgetting.
Running 100% Methanol
All tuned on AEM EMS
On one set of injectors - 700whp
When I switched to both sets of injectors and the car would jump and spin on the dyno. It was looking like ~1000whp on the second set.
And video of it running prior to getting it all together and tuned on the new set up.
http://www.addictsracing.com/fire-breathing-type-r
Old Oct 16, 2009 | 06:07 PM
gingas's Avatar
gingas
Car looks good dude although I personally wouldn't have made my R a drag car. Would've prefered a LS model since you went with a LS block. Nice though. What time you're running?
Old Oct 19, 2009 | 07:12 AM
TheAddict's Avatar
TheAddict
on the old set-up ( the pictures you see without the front mount manifold ) I was running mid-low 10's. I don't know an exact number because I lost the time slip and can't verify how accurate my assumption is. But I believe it was a 10.4 on the slicks.
I'm looking for a good 9 second run this next season. I couldn't get it to stay put on the dyno to fully tune the second set of injectors, so I have to figure that out too.
-Josh
Old Oct 20, 2009 | 11:51 PM
Spec R's Avatar
Spec R
looks good. i would change a couple things but its not my car. keep it up
DB Squad
Integra Forum Moderator
Old Oct 21, 2009 | 01:25 AM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
Very nice, I actually have that video favorited on YouTube!!
I say ditch the AEM EMS and go with some real tuning. I'm on eCtune and I love it, and boost by gear FTW!!
