How To: Fix trunk leak
Old Sep 9, 2003 | 04:28 PM
Ken Szoc's Avatar
Ken Szoc
Default trunk leak
93 Honda accord has water leaking into the trunk. Rumor is that some roof drains are plugged?? Does anyone know how to clear these, or what else might be the problem?
Old Sep 12, 2003 | 07:10 AM
JimBlake's Avatar
JimBlake
Could be a couple of things. This is general since I don't have a '93...
Sunroof has a drain in each corner. There's a tube going down somewhere in each rear fender, & sometimes they pull off their drain fittings & drip into the trunk instead.
Taillight gaskets often leak. Take off your taillight housings & look for torn or crumbly gaskets where they mount against the sheetmetal.
A friend had a rust hole in that channel around the trunklid weatherstripping. It's supposed to be like a raingutter for water to flow down towards the bumper, but there was a hole...
Old Sep 27, 2003 | 04:35 PM
chasloa's Avatar
chasloa
you can buy weatherproofing sealant to fix it if this is the problem
Old Sep 27, 2003 | 05:35 PM
YeaItsAFourDoor's Avatar
YeaItsAFourDoor
..::-Free your mind-::..
Better hurry...too much rain water makes the car stinky...
Old Sep 30, 2003 | 09:35 AM
all motor 91ef's Avatar
all motor 91ef
USDM spec
the most common one, is usually the taillights. Give that one a try. If not just throw some fish in there and enjoy.
