DIY Cylinder Head Porting (port and polish)
Old Aug 27, 2003 | 12:47 PM
Civic Type Sev's Avatar
Civic Type Sev
Default DIY Cylinder Head Porting (port and polish)
I found this really informative site which has a DIY for cylinder head porting. There are tons of pictures and examples. Although they use a V8 cast iron head as an example they give tips on how to work with aluminum heads as well (like hondas). I haven't done this myself but am planning to do so next summer when I build my engine up. I'm sure this could be very usefull for other people on here.
Go check it out on '' http://www.sa-motorsports.com/diyport.htm ''
Go grinding away!!!
Old Aug 30, 2003 | 01:10 PM
jackasssi's Avatar
jackasssi
Allstar
just dont let your every day driver be your 1st attempt unless you have an extra head laying around.
Old Sep 21, 2003 | 06:28 AM
agileauto.com's Avatar
agileauto.com
pretty much dude. unless you are properly equiped and have been trained, you are likely to be unhappy with the outcome.
Old Jan 27, 2005 | 07:23 AM
davidn71's Avatar
davidn71
95 Civic w/ b16 swap
Honestly, you can do a mild port and polish job, just don't get carried away. The main thing is removing all the carbon build up. No fuel additive will do that for you, no matter what the can says...
Old Jul 3, 2006 | 09:17 AM
adva7328's Avatar
adva7328
BOOST PROJECT 99
that is very good info
Old Jul 4, 2006 | 10:42 PM
eonsx311's Avatar
eonsx311
today is not my birthday.
what actually is the main thing is to not slow indutcion velocity. Many port jobs go wrong when people remove material in the wrong places. If you disrupt the velocity if the air flow to the point that flow is in a sense "too easy" you actually end up preventing proper intake...
Old Aug 1, 2006 | 12:47 PM
gsr converters's Avatar
gsr converters
i think i'd just leave it to the pros
Old Aug 4, 2006 | 08:51 AM
ALLMOTOR18's Avatar
ALLMOTOR18
EXACTLY!
