eg rear seats
i was wondering if anyone can help me out on how to remove your stock eg hatch rear seats...i know plenty of you guys did it any tips??where to start??? let me know thanks..
1- lift up the carpet/board in the back, There is a screw under the bottom pad on the drivers side/ middle. You get to it from the trunk. it doesn't look like it does anything but the bottom fome is hooked on to it with a little metal loop. Unscrew it all the way.
2 Rip out the bottom now from the back part -towards the front 3. there are 2 clips now on the backrests that need to be pushed out (SAVE THESE CLIPS) You will see them on the little rod that the backrests pivot on. The clips are on the side toward the window. 4. Push backrests towards side widow and remove |
