Inline fuel pump wiring
Old Aug 5, 2003 | 11:39 PM
luti's Avatar
luti
Default Inline fuel pump wiring
I hope this is the right section to post this under, I am also going to post the same message under 92+ Civic and Engine Tech.
I am installing an inline pump in my engine bay (yeah I know the cons to doing this...) and I need to know of a good place to tap either a 12 volt source or a place to put a relay to run the pump. Any recommendations?
Old Aug 6, 2003 | 09:31 AM
luti's Avatar
luti
ttt
Old Aug 6, 2003 | 04:49 PM
drift's Avatar
drift
Flaccid Member
the battery
Old Aug 6, 2003 | 05:31 PM
luti's Avatar
luti
Originally posted by drift
the battery
Yeah, but if I run it from the battery it will be on even when my car is off, that's why I need to know of a source to use for the relay.
Old Aug 7, 2003 | 11:57 AM
-=ELF=-'s Avatar
-=ELF=-
connect inline pump to main relay(it's working with fuel pump)
how to find it - read another you topic about vacuum line, there link
some difference with install in my car and in link about setup:
my Civic 92 from Europe(left side drive): main relay placed not at right side(if you driver) as in install manual, it's placed at left side, near the fuses.
