Can anybody help me about adjusting the gear ratios?
Old Jul 5, 2003 | 09:34 PM
MNposterChild's Avatar
MNposterChild
Default Can anybody help me about adjusting the gear ratios?
I am looking to adjust the 5th gear ratio. Can anybody help me out how to do so?
Old Jul 8, 2003 | 11:06 PM
PHiZ's Avatar
PHiZ
BOOST GOD
you're looking at removing your transmission, and having it rebuilt with a different gear where 5th used to be.
It's a process probably best left to a tranny shop.
-PHiZ
Old Jul 9, 2003 | 10:44 AM
MNposterChild
Yea.. I'm not serious about racing my car...just want a larger 5th gear so I don't wear out the engine while driving on freeways (and a higher top speed would be nice). Any idea as to about how much this would cost?
Old Jul 9, 2003 | 06:40 PM
MikeR's Avatar
MikeR
never heard of it done, 5th gear is pretty well tuned, i think the cost would be alot more than the benefit. but it couldn't hurt,
Old Jul 9, 2003 | 08:52 PM
sts2poc1's Avatar
sts2poc1
try different tire diamiters that will change your gearing too
Old Jul 9, 2003 | 09:28 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Wow dude, good point. I always try to make things as complicated as possible.
-PHiZ
Old Jul 11, 2003 | 07:58 PM
sts2poc1's Avatar
sts2poc1
-PHiZ
thanks man
Old Dec 28, 2006 | 12:10 AM
vicentino's Avatar
vicentino
after changing tire diameter, the speedometer will be off. How do I adjust it in my 95 accord dx? It really did change the gearing.
Old Jan 11, 2007 | 11:58 AM
quik's Avatar
quik
1337 h4x0r
You have to adjust the VSS (Vehicle Speed Sensor) located somewhere on/near the axle. Don't do it.
Old Jan 16, 2007 | 12:30 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
http://www.fatboyraceworks.com/gears/index.php
that'll make a graph to show what tire sizes will do when u change them.
it says
195/50-15's at 4000rpms will be at 81mph
195/60-15 at 4000rpms will be at 83mph.
im sure u can mess around with it a little more to make it better.
it'll also mess with the mileage on the odometer...
