92 hatch stock rims
Old May 20, 2003 | 07:11 AM
tunda's Avatar
tunda
Default 92 hatch stock rims
I was wondering is it possible to paint my stock 92 hatchback rims (which are currently cromish like) black???
should i take the tire off sand down the rust and then do it...let me know if you ever did it or anything...what kinda of spray paint should i use...
i dont really want to buy rims yet...im going all speed for now peace..
Old May 20, 2003 | 12:12 PM
BlackEG_Si's Avatar
BlackEG_Si
this guy does a pretty good job explaining it
http://www.honda-tech.com/zerothread?id=316500
basically, you just need to sand everything off of your wheels, get them nice and smooth. keep everything dust free (get a tack cloth from hardware store). stuff some index cards under the lip to protect the tires. maybe spray some primer. spray your desired color, and then some clear coat if you like. all the paint can be found at car parts stores. obviously, time is needed in between coats, so you might want to secure a ride to wherever you might need to go during the drying process.
maybe while you're under there, you can paint your calipers too.
i'd say, do some research into polishing metal with sandpaper. there are techniques like wet-sanding that you need to learn. after that, it's all prep work and painting. oh yeah, and remember, spray lots and lots of very very light coats. you will appreciate it.
Old May 20, 2003 | 12:54 PM
tunda's Avatar
tunda
thanks ;]
Old Jun 7, 2003 | 09:25 PM
plejtoj's Avatar
plejtoj
i painted mine black. theres only one rim that u can see tho. i was tryin on this rim i got from someone.
File Type: jpg
