shaving side moldings
Old May 16, 2003 | 04:37 PM
SoSoDef24's Avatar
SoSoDef24
Default shaving side moldings
i want to take the side moldings off my car before i paint it. i tried to fill the holes with bondo but it won't stay on without caving in. what should i do?
Old May 16, 2003 | 11:24 PM
Motohip's Avatar
Motohip
weld metal to it. Bondo will deffinitely not hold.
Old May 17, 2003 | 07:22 AM
SoSoDef24's Avatar
SoSoDef24
sounds like a good idea. good thing i am a good welder
Old May 17, 2003 | 04:21 PM
Motohip's Avatar
Motohip
Cool, wish I had some kinda useful skill
Old May 19, 2003 | 07:46 AM
armada_v's Avatar
armada_v
Just remeber to do tack welds and jump from one part of the door to another. Don't try to do a long seam, or you will warp the hell out of your doors. Good luck.
Old May 25, 2003 | 12:28 PM
5thgenacc's Avatar
5thgenacc
you can use bondo to smooth it out but you still have to weld them up first
Old May 25, 2003 | 03:25 PM
SoSoDef24's Avatar
SoSoDef24
so:
i should make small little pieces to fit over each hole, weld them, then it all down and use bondo to smooth it out.
Old May 27, 2003 | 12:42 PM
STOCK96civicDX's Avatar
STOCK96civicDX
I take care of my member
you can take it to bare metal and then use fiber hair. stuff is harder than a rock when dry and has a fast set time. Bondo makes it as well as other companies. The bonus is that it won't crack like regular body filler if it's banged around.
