Need Help With My Headlight Wiring
Old Apr 2, 2003 | 03:59 PM
97GZR's Avatar
97GZR
Default Need Help With My Headlight Wiring
NEED HELP WIRING MY BLACK HOUSING HID'S THAT I GOT FOR MY JDM CONVERSION ON MY 97 GSR. ANYONE OUTHERE PLEASE I AM DESPERATE
Old Apr 23, 2003 | 10:47 PM
penhtaing's Avatar
penhtaing
It depends on what kind of kit you have. I used the factory phillips ballast and d2s bulbs with an audi a4 retrofit onto my 99 civic. For this kind of swap, you would need a harness for your swap. It will have a connector for your stock 9006 headlight, 2 12volt relays, 1 or 2 ground cables and 2 15 or 20amp fuses connected to the power line (which connects directly to the positive terminal of the battery). Everything for the harness is a direct plug in. You should be able to figure out how to wire it when you get it. Here's a good website that can help you out. http://faq.auto.light.tripod.com/headlamp-faq.htm (just check on the ELECTRICAL-WIRING RELATED link
Old Apr 24, 2003 | 09:19 AM
97GZR's Avatar
97GZR
I need to get an audi a4 harness? maybe I misunderstood, what harness do you recommend that I get?
Old May 30, 2003 | 12:36 AM
penhtaing's Avatar
penhtaing
You can make your own wiring harness as described or you can by one from an online site www.suvlights.com They're very helpful people and they have a harness for you're 9006 socket. You will not need the audi harness, you will need one for your car which is a 9006 socket.
