Is A Rear Disc Conversion Possible?
Old Mar 21, 2003 | 08:20 PM
screwd04's Avatar
screwd04
Default rear disk conversion!
Hey does anyone know exactly what i would need to do a rear disk conversion on my 1994 ex. Please list. Could i use the oem front calipers and rotors since the oem rear are smaller?
Old Mar 27, 2003 | 06:22 PM
92lx
Guest
Posts: n/a
No, you can't use the front calipers as you'd lose a parking brake. And if you use the rotors they are the wrong thickness and you'd need some kind of shim probably.
You need the entire rear suspension of a 90-97 accord with rear disk brakes. And you need the proportioning valve and master cylinder from that car as well, and disk-brake equiped brake lines (preferably Stainless Steel).
There are some how-tos out there, it's really basic though, the hard part is aligning the rear after you do it. ESPECIALLY if your lowered and no one will do it, and you have to do it manually like I will have to in a few weeks
Old Apr 28, 2003 | 05:47 PM
R92680's Avatar
R92680
what type of 94 ex is it and that would help out if it is accord go with what he said and if it is civic get a teg ls or gsr rear suspension(trailing arms,lines,calipers,rotors)the whole works
Old Jul 1, 2003 | 10:22 PM
Technodigifreak's Avatar
Technodigifreak
Hot-Modder
they do make 4 wheel disc conversions for civics and accords, the only problem is their about 1500$ and a real pain in the ass to install, so buyer beware
Old Jul 9, 2003 | 01:43 PM
StealthAccord's Avatar
StealthAccord
would a front upgrade on discs and rear drum upgrade hurt?
Old Jul 9, 2003 | 07:20 PM
Technodigifreak
Hot-Modder
no it won't hurt, then only thing it can do (if YOU know what your doing) is uprgade your overall braking
Old Jul 10, 2003 | 06:36 PM
Snoopy's Avatar
Snoopy
been there done that
yea aem makes a rear disk conversion for ex's
Old Jan 17, 2004 | 10:26 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
you need the rear disc setup fron a 94-01 teg,
92-95 civic si or ex with rear disc
or a del sol with rear disc
or a 99-00 civic si.
a 4040 porp valve from a civic si, teg ,del, or older civic si.
you need a master cylinder and brake booster from a teg or civic si prefferably.
Old Oct 16, 2005 | 09:00 AM
zimbo's Avatar
zimbo
Sorry for high jacking the thread, but what all would I need to perform a rear disc conversion on a 98 Civic EX? Mostly what I need to know is what years of other cars/models' rear brake systems will fit a 98 Civic EX.
